It is currently Sat Jul 26, 2025 6:08 pm
PostPosted: Mon Jun 13, 2005 3:52 am
State: ON
I’m looking for a good guitar polish that I can include with my guitar care packages. I really like the Preservation polish from StewMac, but it is now one of the products that they will not ship outside of the USA. So I just thought I would see what else you guys would recommend.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Mon Jun 13, 2005 4:38 am
McGuire's #9 (or higher if they make it) will make a good polish.
PostPosted: Mon Jun 13, 2005 5:22 am
Oz. Available through Constantine's and a few other places.
PostPosted: Mon Jun 13, 2005 5:24 am
Any custom car shop should have it. I use #7 and then #9
PostPosted: Tue Jun 14, 2005 12:36 am
I would use the #7 for polish #9 is a pit too corse for my liking. Now to remove some light pick scratches use #9 followed by #7 to polish out.MichaelP38517.648900463
PostPosted: Tue Jun 14, 2005 6:15 am
Guys, be careful...on some of these brands the higher number doesn't mean a finer grit. Read the bottles!
Carlton
PostPosted: Tue Jun 14, 2005 6:33 am
McGuire's #7 is finer grit than McGuire's #9 I think that is how I stated it. #7 polish (finest), #9 swrill remover (a bit corser)
PostPosted: Wed Jun 15, 2005 12:17 am
I got some wise advice regarding this topic from a wonderful builder and even better finish man (John Watkins). He said, and looking back at experience I agree, that any of the compounds previously stated, my statements included, are not actually polishing compounds but rather finishing compounds. If you use a #7 for polishing, you'll most likely have to use something to get the film off from the compound. Michael, I'm confused by your #7 being finer than #9 post. I've always been under the impression that McGuires is "higher number, higher grit". I've got some #10 that is "Clear Plastic Polish" which is used to take the scratches out of plexi and the like. My #7 or even #9 would just add scratches to the plastic.
So with John's advice at the top of my mind, Josh, you should think twice about including any compound with your care package. It's sort of like including a truss rod wrench, the buyer is going to screw it up, it's just a matter of time. If someone were to buy a new guitar that costs a lot of money, they would be likely to want to polish it every time they get a fingerprint on it. If they used compound, no matter how fine, it would only be a matter of time before the guitar would be coming back to you with a burned-through area in the paint. Why not just include a soft buffing cloth and if they get something on it that won't come off with that, recomend a spritz of water.
PostPosted: Wed Jun 15, 2005 12:30 am
Here is the maguires I use and as you can see the numbers dont necessarily indicate a finer grit compound.
Also, Novus works well even on french polishes.
PostPosted: Wed Jun 15, 2005 12:52 am
Look at the chart on the back of the bottle it has a graft showing the grit rating. put it on you finger and fell it is noticble. I could be thinking backwards but I dont believe so. The #7 is a glaze intended to use to buff out a finish to high sheen. #9 is swirl remover intended to remove oxdidation and shallow swril marks and scratches. If I am wrong I will stand corrected and set in the corner and pout
If you look at you posted pic notice ther is no relationship between the grit and the product #. My guess is the number is just the order they released the product.MichaelP38518.4149305556
PostPosted: Wed Jun 15, 2005 1:46 am
State: ON
this has been helpful.
Josh
Josh House
PostPosted: Wed Jun 15, 2005 1:53 am
MP I think you last comment is most likely true. The number and the grit might not really have anything to do with each other.
PostPosted: Wed Jun 15, 2005 3:22 am
I concur with MP. #7 is finer than #9. I used to use #9 but once it dries it can leave white gunk in crevices where #7 doesn't leave any residue. I use #7 before the guitar goes into the case.
tim...
PostPosted: Wed Jun 15, 2005 4:36 am
Well, I guess there is no method to their madness. I KNOW #10 is finer than #9. It feels like Pledge (pretty much milky water) No grit at all to the touch. Go figure...
PostPosted: Wed Jun 15, 2005 5:13 am
[QUOTE=MichaelP] McGuire's #7 is finer grit than McGuire's #9 I think that is how I stated it. #7 polish (finest), #9 swrill remover (a bit corser)[/QUOTE]
Michael,
Sorry, it looked like I was replying earlier to your post, but I was actually alerting some of the others who were misunderstanding the crazy numbering systems of polish manufacturers.
Even dealers get it wrong. Here's an example: I ordered "fine" and "super fine" polish from LMI. They're both Meguiar's products. They arrived with LMI's own lables on them--"fine" on the #10 bottle, and "super fine" on the #17 bottle. Makes sense, right? Wrong! Luckily, I read the bottles. Clearly stated on the back of the #10: "If surface requires light restoration, precede with Meguiar's Mirror Glaze Clear Plastic Cleaner (No.17)." The #10 (Meguiar's Clear Plastic Polish) is FINER than the #17 Clear Plastic Cleaner. Even LMI has it mixed up! What's a poor boy to do?!!
Carlton
PostPosted: Wed Jun 15, 2005 12:03 pm
The nice thing about using #7 is that it doesn't contain any oils, waxes or silicone. This is very helpful in case you have to do a drop filling
tim...
